NL-Legacy99 Posted July 3, 2016 Share Posted July 3, 2016 Any thoughts on these rims, not to bad of a deal just wanted to know if they would look any good on the car they are 18 inch 5x100. Thanks Link to comment Share on other sites More sharing options...
Perscitus Posted July 3, 2016 Share Posted July 3, 2016 If they look good to you, thats all that matters. I see 18x8 ET/+42mm so they will fit fairly well, poke out more than stock wheels, but not enough to require any pulls/rolls or rub anything unless you get very tall and fairly wide tires. Wrap them in some 225/45 or 235/40 rubber. http://www.willtheyfit.com/index.php?width=225&aspect=50&diameter=17&wheelwidth=7.5&offset=48&width2=235&aspect2=40&wheel_size=18&wheel_width=8-5&offset2=42#isPage=1 http://www.willtheyfit.com/index.php?width=225&aspect=50&diameter=17&wheelwidth=7.5&offset=48&width2=225&aspect2=45&wheel_size=18&wheel_width=8-5&offset2=42#isPage=1 [url=http://www.willtheyfit.com/index.php?width=225&aspect=50&diameter=17&wheelwidth=7.5&offset=48&width2=235&aspect2=40&wheel_size=18&wheel_width=8-5&offset2=42#isPage=1][/url] Link to comment Share on other sites More sharing options...
Scooby Fan Posted July 4, 2016 Share Posted July 4, 2016 Those should look good...and really it only matters if they look good to you...... I run 18x8 with 45 offset... 245/40/18.... nice fit no problems at all. Make sure the hub bore is correct or there are hub centric rings with the wheels and away you go. Link to comment Share on other sites More sharing options...
