FLlegacy Posted October 10, 2016 Share Posted October 10, 2016 Well since you aren't likely to get warranty coverage anyway, http://www.ebay.com/itm/162232590279?item=162232590279&frommaketrack=true&viewitem=&vxp=mtr Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 10, 2016 Share Posted October 10, 2016 From my drive home today: 40 on Cylinder 1, 295 on Cylinder 2, 2 on Cylinder 3 and 3 on Cylinder 4. Stalled about 3 times, once it warmed up it ran absolutely flawlessly... How did you get these numbers? Link to comment Share on other sites More sharing options...
MGT Posted October 10, 2016 Share Posted October 10, 2016 How did you get these numbers? Torque Pro app and a cheap OBD II adapter Link to comment Share on other sites More sharing options...
hadvw Posted October 10, 2016 Share Posted October 10, 2016 Same issue I'm having ('05 5EAT). Runs great for 2-4 minutes after cold start (just like you, not super cold - NorCal here). Then runs badly for about 1 minute, then after it warms up again, just fine. Misfires on cyl3 (had a CEL for it once), and a few on cyl1 (hooked up Btssm today). Plus a few knock events. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 10, 2016 Share Posted October 10, 2016 Bad coil? Dirty MAF? Link to comment Share on other sites More sharing options...
hadvw Posted October 11, 2016 Share Posted October 11, 2016 I cleaned (at least tried) to clean the MAF last summer with CARB cleaner, IIRC. Also, wouldn't MAF affect both sides? And a bad coil only one cylinder? Yeah, probably should swap 1/3 and see if the misfire follows that.. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 11, 2016 Share Posted October 11, 2016 I cleaned (at least tried) to clean the MAF last summer with CARB cleaner, IIRC. Also, wouldn't MAF affect both sides? And a bad coil only one cylinder? Yeah, probably should swap 1/3 and see if the misfire follows that.. In case noone ever told you, Link to comment Share on other sites More sharing options...
MGT Posted October 11, 2016 Share Posted October 11, 2016 I've also tried cleaning the MAF with that and no luck for my issue. Link to comment Share on other sites More sharing options...
hadvw Posted October 11, 2016 Share Posted October 11, 2016 Yeah, that looks familiar. I think that's probably what I used.. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 11, 2016 Share Posted October 11, 2016 Torque Pro app and a cheap OBD II adapter I am surprised that Torque can read the misfire parameters. Last time I used Torque was late 2014, and it did not have the ability to read these. Did you enter specific PIDs in it to be able to read these variables? Also, what is strange to me is that you got 200+ misfires on one cylinder. From my experience with btssm, the misfire count can only go up to 99 and then gets reset. I can't recall, did you get two CEL codes? Misfire codes for cylinder 1 and 2? Link to comment Share on other sites More sharing options...
MGT Posted October 11, 2016 Share Posted October 11, 2016 I am surprised that Torque can read the misfire parameters. Last time I used Torque was late 2014, and it did not have the ability to read these. Did you enter specific PIDs in it to be able to read these variables? Also, what is strange to me is that you got 200+ misfires on one cylinder. From my experience with btssm, the misfire count can only go up to 99 and then gets reset. I can't recall, did you get two CEL codes? Misfire codes for cylinder 1 and 2? I've only ever gotten a CEL code for cylinder 2. Here is a link to the report: http://pastebin.com/SdgB5uHL A couple tests show as incomplete because I had recently had the battery disconnected which reset the ECU, that probably contributed to the stalling because Idle hasn't properly been relearned but the misfire is there nonetheless. Link to comment Share on other sites More sharing options...
