ehsnils Posted July 27, 2016 Share Posted July 27, 2016 Just make sure that all hoses went on as they should have on the T connector and that they aren't cracked then. Link to comment Share on other sites More sharing options...
WahooNo2 Posted August 4, 2016 Share Posted August 4, 2016 did you check that the intercooler to throttle body hose is still attached tightly? i had the clamps brake on mine and i couldnt make boost., i have also had the end bits slip off where the clamps go on. Also make sure the blowoff/bypass valve isnt broke Link to comment Share on other sites More sharing options...
Anavrin351 Posted August 7, 2016 Share Posted August 7, 2016 12.6 isn't that bad. I just found out I'm only making 10. Thought that was normal until a half hour ago when j sent a data log to a friend and he told me its low. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted August 7, 2016 Share Posted August 7, 2016 The boost may also be limited if you have knocking. Link to comment Share on other sites More sharing options...
