robot8282 Posted June 22, 2016 Share Posted June 22, 2016 Would anyone be able to tell me if the analog climate control is plug and play with the digital JDM double din center console? http://images.dealer.com/evox/stills_0640/4215/4215_st0640_055.jpg ^^This is essentially what is in my car now, except I have a double din. However, I would really like to install this one below, but i want to know first if everything will just plug right in http://www.avojdm.com/product_info.php?products_id=200 Link to comment Share on other sites More sharing options...
CatInTheDryer Posted June 22, 2016 Share Posted June 22, 2016 Manual and automatic climate controls are two different beasts...you could technically do it but you would end up replacing a lot of parts and spending a ton of cash. It would probably be cheaper to sell your car and buy one with the automatic climate if you want it that bad. Link to comment Share on other sites More sharing options...
AutoXCivic Posted June 23, 2016 Share Posted June 23, 2016 https://www.amazon.com/Scosche-SU2025B-2005-Up-Subaru-Outback/dp/B001EBJTK6/ref=sr_1_1?ie=UTF8&qid=1466715527&sr=8-1&keywords=legacy+gt+double+din Ta da! Slightly cheaper solution. Unless you're actually going for the auto climate control and not just the double din. Link to comment Share on other sites More sharing options...
CatInTheDryer Posted June 24, 2016 Share Posted June 24, 2016 Based on his post it sounds like he already has that kit. Link to comment Share on other sites More sharing options...
AutoXCivic Posted June 24, 2016 Share Posted June 24, 2016 Reading owns me. :/ Link to comment Share on other sites More sharing options...
robot8282 Posted June 24, 2016 Author Share Posted June 24, 2016 https://www.amazon.com/Scosche-SU2025B-2005-Up-Subaru-Outback/dp/B001EBJTK6/ref=sr_1_1?ie=UTF8&qid=1466715527&sr=8-1&keywords=legacy+gt+double+din Ta da! Slightly cheaper solution. Unless you're actually going for the auto climate control and not just the double din. Yea that's the dash that's in my car right now, thank you though. I've understood this is a way more complicated task than I was originally thinking it was going to be Link to comment Share on other sites More sharing options...
