jeannie Posted June 20, 2016 Share Posted June 20, 2016 So I was cleaning my battery terminal when I noticed this hose was kind of cracked And messed up. I've been trying to find it in the manual but I can't. So I was hoping you guys might know what this hose is for? Here's some pictureshttp://uploads.tapatalk-cdn.com/20160620/363c5dc6f52f2a13f6dd75ed0a448534.jpghttp://uploads.tapatalk-cdn.com/20160620/75c715633adcdba698fb858c45908d41.jpg Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
chucks06LGT Posted June 20, 2016 Share Posted June 20, 2016 Looks like maybe a return hose for the fuel.... Link to comment Share on other sites More sharing options...
utc_pyro Posted June 20, 2016 Share Posted June 20, 2016 The middle one is an emissions line going to the fuel tank. Something to do with evaporative emissions. The top and bottom two are fuel lines. Link to comment Share on other sites More sharing options...
jeannie Posted June 20, 2016 Author Share Posted June 20, 2016 Ok thank you!! Do you think that would make a p0171 code come up? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted June 20, 2016 Share Posted June 20, 2016 In my opinion no. P0171 is system too lean. Do you have any mods? My guess is maybe an intake leak somewhere, or disconnected vacuum hose. *In the link below, covertrussian basically says that hose sends fuel vapors to be burned instead of them being vented to the atmosphere. http://legacygt.com/forums/showthread.php/middle-hose-fuel-hard-lines-going-into-and-under-intakei-227855.html So on second though, I guess it is possible that hose could contribute to p0171, but i don't know, I'm interested to hear what others say. Link to comment Share on other sites More sharing options...
jeannie Posted June 20, 2016 Author Share Posted June 20, 2016 Well I reset my ECU and the check engine light hasn't come back on yet anyway. So we will see what happens. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
GeraldG Posted June 20, 2016 Share Posted June 20, 2016 This happened to me a month ago. Flashing cruise with CEL. Same code. It was just a diconnected hose. Link to comment Share on other sites More sharing options...
jeannie Posted June 20, 2016 Author Share Posted June 20, 2016 Really that sucks. I just got my fuel pressure regulator fixed so hopefully that was it Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
BGSEXXE Posted June 20, 2016 Share Posted June 20, 2016 This happened to me a month ago. Flashing cruise with CEL. Same code. It was just a diconnected hose. Which hose was disconnected? I just got a P0172 code last week... Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted June 20, 2016 I Donated Too Share Posted June 20, 2016 Could be any of several. Favorite places to look are the blue T under the intercooler - I've had the FPR hose pop off a few times which is on right hand side - intake number 4 and the MAP sensor hose recently came off too - front of intake behind the alternator - but run the car and listen for sucking hissing sound is how I usually find them! Link to comment Share on other sites More sharing options...
