SpecBinNB Posted June 13, 2016 Share Posted June 13, 2016 Hey guys I was wondering if any of you can shed some light on why my A/F Correction #1 is fluctuating so much? It's been driving me nuts. Drives fine with moderate load but when cruising or light load I can watch the L/100km needle in my cluster swing like a pendulum. Both O2 sensors have been replaced with no change, and a new MAF as well. Boost tested and no leaks were found. Could a failing injector cause this? Bad spark plugs or a coil? What should I look at next? I've attached a couple logs.romraiderlog_20160608_153158.csvromraiderlog_20160608_154420.csvromraiderlog_20160608_153701.csv Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 13, 2016 Share Posted June 13, 2016 If you want, we can set you up with a ETUNE and will definitely address and track down any problems. We do open source quite often. Shoot us a PM if interested. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
