07spec Posted June 9, 2016 Share Posted June 9, 2016 A/C has started doing weird things in my 07 SpecB. Not sure if its A/C or something computer related with the auto climate control. Occasionally, and not every day, put on particularly warm days like 70+ the A/C will come on, blow cold and hard for maybe 10 minutes, then turn off and blow HOT air. This is with the auto climate control set at anything, from 69-75. I have changed it around many times. If I press OFF< then wait a minute, press auto, it will blow full fan super cold air with A/C on for about 10 seconds, then super HOT. Changing the temp, pressing A/C on or off, none of those things help. It will blow HOT air for ever then even when its in direct sun and its 90 degrees out, I can't get the A/C to come on again. UNLESS, If I turn the CAR off, wait 5 minutes and turn it on, it will blow super COLD again, and then stop after a few minutes and blow SUPER HOT. No A/C. Cant get A/C to come back on then. Compressor problem? A/C clutch? Refrigerant problem? Or something computer related? Car started doing this about a month ago, A/C and everything always had been working awesome since 2007. Anyone have any thoughts? Or anything I can do to diagnose the issue further? I checked codes with OBD2 and no codes, nothing weird in the engine data either. Thanks Link to comment Share on other sites More sharing options...
Bettlebob Posted June 9, 2016 Share Posted June 9, 2016 I had a similar issue with mine, ’08 Outback XT, and it ended up being the AC relay under the hood. I took it to the dealership and they could never get it to act up. It finally got to the point that turning the car off wouldn’t reset it and I was stuck with hot air blowing out. I looked and noticed that the sub fan relay and the AC relay were the same part so I switched them, AC worked fine. I ordered a new relay and have not had any issues for about a year now. Link to comment Share on other sites More sharing options...
07spec Posted June 9, 2016 Author Share Posted June 9, 2016 thanks. so you just switched the relays around? was one relay bad? Link to comment Share on other sites More sharing options...
Bettlebob Posted June 9, 2016 Share Posted June 9, 2016 Yeah, the relay for the AC was bad. I switched them, turned the car on and had cold air. To be sure I let the car run a bit the compressor turned on and off like it was supposed to, so I ordered a replacement relay online for about $7. I haven't had any issues since then. Here is a link form Outback.org where they are talking about the same issue that I had and changing the relay. http://www.subaruoutback.org/forums/66-problems-maintenance/26071-c-intermittent-failure-flaky-relay.html Link to comment Share on other sites More sharing options...
fotofan Posted June 10, 2016 Share Posted June 10, 2016 If it's not that it could be the expansion valve at the evaporator. Relay sounds likely though. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
Wagonation Posted June 10, 2016 Share Posted June 10, 2016 A/C magnetic clutch could be failing. Seems to be a common problem with these cars at this age. Both of my 05s died one after another in the last year. Link to comment Share on other sites More sharing options...
07spec Posted June 15, 2016 Author Share Posted June 15, 2016 thanks guys, I am going to do the relay swap today and see if it helps. Link to comment Share on other sites More sharing options...
07spec Posted June 27, 2016 Author Share Posted June 27, 2016 And, the relay was the culprit! Bought a new relay for 8 bucks, swapped it out, A/C has been blowing cold for over a week now! Thanks! Link to comment Share on other sites More sharing options...
