Senzhu Posted June 4, 2016 Share Posted June 4, 2016 Hey Legacy fam, I am pretty stuck right now trying to swap out my light bulb. I want to know if i have to unscrew the little small screw in there in order to get the bulb out or is there another way? God help, i cant believe how hard it is to swap headlight bulbs man. http://i65.tinypic.com/160wpkw.jpg http://i68.tinypic.com/2ykx55h.jpg Link to comment Share on other sites More sharing options...
Senzhu Posted June 4, 2016 Author Share Posted June 4, 2016 http://i66.tinypic.com/ing01c.jpg http://i64.tinypic.com/e7dwyt.jpg Link to comment Share on other sites More sharing options...
wrxwhit Posted June 4, 2016 Share Posted June 4, 2016 No no, just unlock clip and remove bulb, do not touch the screw Link to comment Share on other sites More sharing options...
Senzhu Posted June 4, 2016 Author Share Posted June 4, 2016 No no, just unlock clip and remove bulb, do not touch the screw Thanks for the fast reply!!! Im tryna find how to unlock it... Link to comment Share on other sites More sharing options...
Syndicate Posted June 4, 2016 Share Posted June 4, 2016 ...the low beam bulbs are held in by a retaining clip not a screw, it's that clip you see behind the bulb. Link to comment Share on other sites More sharing options...
Senzhu Posted June 4, 2016 Author Share Posted June 4, 2016 ...the low beam bulbs are held in by a retaining clip not a screw, it's that clip you see behind the bulb. I cant figure out for the life of me how to unlock this clip. I dont wanna put too much pressure and end up messing it up ughhhh Link to comment Share on other sites More sharing options...
Zee199969 Posted June 4, 2016 Share Posted June 4, 2016 Its aways been easier for me to pull the bumper and then the headlight housing to access the bulbs. I had a difficult time trying to access the bulbs thru the wheel well My "Build" Link to comment Share on other sites More sharing options...
FLlegacy Posted June 4, 2016 Share Posted June 4, 2016 Push on the little u shaped end and then guide it up and around the lock. It's a very simple clip. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted June 4, 2016 Share Posted June 4, 2016 http://uploads.tapatalk-cdn.com/20160604/00fd4083836a8a37b9985238bf02bfdb.jpg Hope that helps! Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Senzhu Posted June 4, 2016 Author Share Posted June 4, 2016 http://i65.tinypic.com/18hmhs.jpg Got it in finally. Will do the other side tmrw morning xD Link to comment Share on other sites More sharing options...
blklgt05 Posted June 4, 2016 Share Posted June 4, 2016 Yeah +1, I'd just remove the headlights, easier that way. mod journal Link to comment Share on other sites More sharing options...
Ellesedil Posted June 4, 2016 Share Posted June 4, 2016 Headlight replacement is on my list of things to do since I have a lowbeam that's out. As soon as I buy some lights So, this is timely info for me. Link to comment Share on other sites More sharing options...
DugsSin Posted June 4, 2016 Share Posted June 4, 2016 Once you've changed out a set it's much easier working blind and contorted. That spring clip works so easy just using one finger tip to gently push in then down to unhook it then it SWINGS out of the way. DO NOT try and remove it completely Also note how the original bulb is seated in the socket or you will be back. There are two small tabs at top of arch on fender that should be slightly bent to allow the liner to come down far enough to get in. Great pic FLlegacy. Link to comment Share on other sites More sharing options...
