Pecosgaspacho Posted May 23, 2016 Share Posted May 23, 2016 My daughter has a 03 legacy with a stock 2.5l and around 100k miles. She brought it home from college and I am taking a look at it . Seems to have some rod knock. I took it to a local subaru guy who quoted me around $3500 to fix the rod knock by rebuilding the engine, put in new head gaskets and timing belt etc. My questions 1. Do you think it is worth putting that kind of money into an an 03? 2. Does $3500 seem reasonable? 3. If I do just the timing belt (I can do this myself) is the rod knock going to be an engine killing problem soon? Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 24, 2016 Share Posted May 24, 2016 post a video of the noise. Failed timing belt tensioners could sound like rod knock. this video shows you how to take the timing cover off to look at the tensioner enginesus.com sells rebuilt long blocks. Link to comment Share on other sites More sharing options...
Pecosgaspacho Posted May 24, 2016 Author Share Posted May 24, 2016 Heres a video of the knocking noise. Sounds to me like its coming from inside the engine. Link to comment Share on other sites More sharing options...
Sara32013 Posted May 24, 2016 Share Posted May 24, 2016 I don't believe that's a rod knock. My car sounds almost identical. Does it go away when the car warms up? Try putting a stethoscope on the oil pan, see if it's louder down there. Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 25, 2016 Share Posted May 25, 2016 Hard to tell since you did not rev it. Did it run low or out of oil? Here is what rod knock sounds like. Theses are all subarus Link to comment Share on other sites More sharing options...
Pecosgaspacho Posted May 28, 2016 Author Share Posted May 28, 2016 Heres a couple other videos that might help. It seems worse when its cold and gets better when it warms up but its still there. I took it to another subaru guy yesterday and he seems to think it is piston slap and I shouldn't worry about it. Link to comment Share on other sites More sharing options...
jdmyang Posted June 2, 2016 Share Posted June 2, 2016 Heres a couple other videos that might help. It seems worse when its cold and gets better when it warms up but its still there. I took it to another subaru guy yesterday and he seems to think it is piston slap and I shouldn't worry about it. Ill be honest, I took mines to the dealer and they said it was a piston slap and a few months later it was a rod knock appeared..... https://www.youtube.com/watch?v=8GPzN2CQqdo Link to comment Share on other sites More sharing options...
