Dispatch20 Posted May 22, 2016 Share Posted May 22, 2016 I found some rust starting on the seam weld area on the rear fender. Normally, this area is covered by a rubber guard. I removed that rubber guard a year ago. It's not clear if removing the guard contributed to the rust, or whether the many years of having the rubber guard wore down the paint & galvanized metal. The car lives in the rust belt, so this isn't a huge surprise. Any advice on the smartest way to handle this? The solution doesn't have to look that great as long as it delays the rust from eating the car away. The rust currently isn't perforated through any of the metal. However, it's on the inner seem edge so the surface isn't exactly smooth and easy to correct. Thanks! Link to comment Share on other sites More sharing options...
utc_pyro Posted May 23, 2016 Share Posted May 23, 2016 Sand, use rust converter, paint. Link to comment Share on other sites More sharing options...
Dispatch20 Posted May 23, 2016 Author Share Posted May 23, 2016 Am I overthinking it? Basic primer and paint? Or some fancy rust cover like POR15 or rust bullet? Link to comment Share on other sites More sharing options...
fotofan Posted May 23, 2016 Share Posted May 23, 2016 That's such minimal rust, if you'd sand it down to bare metal where there's no rust left, then just hit it with a coat of primer and a couple of paint it would be just fine. Rust converter never hurts though. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
Dispatch20 Posted May 24, 2016 Author Share Posted May 24, 2016 Rust converter relies on leaving rust on the surface so that it can bond/chemically change it. On a fender like this where I'd have good paint remaining adjacent to an area sanded down to bare metal, I'm not sure it would work. It might be better just to sand and prime. Unless there is a rust converter that would work different than most of the ones I found. Link to comment Share on other sites More sharing options...
