teksimian Posted May 20, 2016 Share Posted May 20, 2016 Planning on replacing the timing belt on my LGT. Car has 144,000KM on it now. I replaced new blue long life coolant into the car at the 96,000KM maintenance point. It's supposed to last 200K i believe. Question is should I just replace the coolant since i'm pulling the rad? If not what should I do to ensure it isnt contaminated when drained and reused? Link to comment Share on other sites More sharing options...
Shadow_419 Posted May 29, 2016 Share Posted May 29, 2016 I would just drain into clean container/buckets. If you want to be extra careful you could strain it through a screen before you refill the radiator. Good luck with the work. Link to comment Share on other sites More sharing options...
fotofan Posted May 29, 2016 Share Posted May 29, 2016 Personally I'd probably replace it (what's $25 when you're doing a T-belt?) but you could get away with leaving it. Just make sure it stays clean. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
Shadow_419 Posted May 30, 2016 Share Posted May 30, 2016 Personally I'd probably replace it (what's $25 when you're doing a T-belt?) but you could get away with leaving it. Just make sure it stays clean. More like $50 because you're going to need about 1 1/2 gallons, but it's up to what you think will be safe. If you don't think you can keep your coolant free of contaminants while you do the work, just replace. Link to comment Share on other sites More sharing options...
