KPH Posted May 19, 2016 Share Posted May 19, 2016 The dual moonroofs (moonrooves?) on my Ruby Suby are stuck in the open position. When I push the open/close button, nothing. No sound at all. I'm a do-it-yourself kind of gal and want to figure this out on my own! Any thoughts on how to approach this? KPH Link to comment Share on other sites More sharing options...
KPH Posted May 20, 2016 Author Share Posted May 20, 2016 I should add that I've got it shut using the manual hex wrench, but I'd like to track down the real cause of the malfunction and fix it. I have a feeling it's not a simple fix...... Link to comment Share on other sites More sharing options...
BDII Posted May 20, 2016 Share Posted May 20, 2016 Did you check the fuse? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
JBisson Posted May 21, 2016 Share Posted May 21, 2016 Now that it's closed will it open on its own? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Subi3snacks Posted May 29, 2016 Share Posted May 29, 2016 The switch could be bad, have you tested it? Link to comment Share on other sites More sharing options...
