JaQuan15 Posted April 25, 2016 Share Posted April 25, 2016 Hello everyone ! I've missed this forum so much , you may remember me from having "White Widow" . Hope everyone is well ... So this is my problem , my friend has recently bought a 2003 Legacy and she said she hears a clicking noise while idling and when she accelerates up to 15 MPH then the noise disappears . I thought it may be her oil or even the head gaskets were starting to go but she said the heads were done "says the previous owner" .. Inside this I have included the video of the noise . Any suggestions on what it may be will be greatly appreciated . https://vimeo.com/164065579 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted April 25, 2016 Share Posted April 25, 2016 Sounds like metal on metal contact. How many miles on the car, 5pseed or auto? Link to comment Share on other sites More sharing options...
JaQuan15 Posted April 26, 2016 Author Share Posted April 26, 2016 Not sure how many miles she has .. It's a automatic I know that . I want to say it's almost 140,000 . Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted April 26, 2016 Share Posted April 26, 2016 If you can get a good video of it from the engine bay that would help a lot. It could be a number of things. Let's hope it's not rod knock and it's a tensioner. either way I'd find out soon cause both can cause the engine to go. If it goes away when the car warms up it's piston slap witch is normal and the car could run a long long time with out any problems. Pull the dipstick and see if you can find any metal flakes. Link to comment Share on other sites More sharing options...
JaQuan15 Posted April 26, 2016 Author Share Posted April 26, 2016 If you can get a good video of it from the engine bay that would help a lot. It could be a number of things. Let's hope it's not rod knock and it's a tensioner. either way I'd find out soon cause both can cause the engine to go. If it goes away when the car warms up it's piston slap witch is normal and the car could run a long long time with out any problems. Pull the dipstick and see if you can find any metal flakes. I really appreciate the great advice . It's always a pleasure getting a response from ya . I will double check with her and tell her what you said . She said the noise goes away after she hits over 15 MPH , but even when the car is idling she said she can hear it .. Link to comment Share on other sites More sharing options...
RumbleRumble Posted April 26, 2016 Share Posted April 26, 2016 Defiantly check the oil level and if you she hasnt changed the oil let do so with at least 5w30 conventional or synthetic blend and you can even replace a quart with stp or lucas oil treatment Link to comment Share on other sites More sharing options...
