ivonr Posted April 23, 2016 Share Posted April 23, 2016 Similar problems on this forum but couldn't find anything like this: From the driver's seat I can't roll down my rear passenger-side window....but I can roll it up no problem The window switch on the rear passenger side works fine Is this a tough fix if I'm not mechanically inclined? Anyone have a DIY or a diagram? Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 24, 2016 Share Posted April 24, 2016 Similar problems on this forum but couldn't find anything like this: From the driver's seat I can't roll down my rear passenger-side window....but I can roll it up no problem The window switch on the rear passenger side works fine Is this a tough fix if I'm not mechanically inclined? Anyone have a DIY or a diagram? well...you have power to the window. rolls one way but not the other from the driver side seat. all other ways work. id seriously check that switch at the drivers door. switch could be dirty or broken. also make sure the wire is connected. Link to comment Share on other sites More sharing options...
ivonr Posted April 24, 2016 Author Share Posted April 24, 2016 Turns out if I mash that button down HARD from the drivers seat, that window will go down Link to comment Share on other sites More sharing options...
I3eXa Posted April 24, 2016 Share Posted April 24, 2016 That master switch in the driver door is notorious for going bad. $120 new or just live with it. The contacts are getting worn is the problem. Sent from somewhere in Potatoland Link to comment Share on other sites More sharing options...
honduhunter Posted April 24, 2016 Share Posted April 24, 2016 /its not too terrible to replace. are you comfortable removing the door panel? Link to comment Share on other sites More sharing options...
