mr_silas Posted April 20, 2016 Share Posted April 20, 2016 2005 Legacy Gt Limited 150k Driving home the other night my car suddenly stopped running and coasted to a stop. Would no re start, just turn over. All electrical works fine. It threw a P0108 which is MAP circuit. I thought it could be a bad sensor but as i investigasted, i found the throttle body hose was disintegrated. And i also couldnt help to notice the throttle body makeing a loud buzzing noice. And as i touch the throttle it changes. Will simply replacing the hose fix my problem? or is there more going on here? Throttle body position sensor? or something else? see following link for video and pictures https://goo.gl/photos/yzcywjaNqza51QY69 Link to comment Share on other sites More sharing options...
mr_silas Posted April 23, 2016 Author Share Posted April 23, 2016 nvm on this thread. found out my timing belt snapped. so now to pull the motor and replace the heads. Yahoo... : / Link to comment Share on other sites More sharing options...
Zack Spec B Posted April 26, 2016 Share Posted April 26, 2016 when was the last time you changed the pulleys, tensioners and belt? Link to comment Share on other sites More sharing options...
