spazlamhaslam Posted April 19, 2016 Share Posted April 19, 2016 After having my 2nd CD player burn out, Ive decided to take matters into my own hands and not paying $300 for that JDM dual climate control kajigger. I bought a standard 14 pin wiring harness and the bluetooth amp, wired it all together and it sounds great! Only problem is I lost any power to climate control. No problem tho, Ill just splice into the 12 volt power, ground, and illuminati from the 14 pin connector and run those back to where they used to be connected in the back of the head unit. But still nothing? I can't think of anything else that would be causing it not to work. Any ideas? I'm sure its a simple fix. Ill post pics when I can. Link to comment Share on other sites More sharing options...
spazlamhaslam Posted April 19, 2016 Author Share Posted April 19, 2016 Good news, turns out I forgot to re route the ignition wire to the old radio. WORKS GREAT!!!!! Write up coming soon. Link to comment Share on other sites More sharing options...
08 LGT Posted April 20, 2016 Share Posted April 20, 2016 Random question since you're here - how's the CNG LGT running? Last I saw you were still tuning it. Link to comment Share on other sites More sharing options...
spazlamhaslam Posted April 20, 2016 Author Share Posted April 20, 2016 Random question since you're here - how's the CNG LGT running? Last I saw you were still tuning it. Its running great! Ive run about 70,000- miles on Cng with no issue. Ill do a write up soon. Link to comment Share on other sites More sharing options...
spazlamhaslam Posted April 20, 2016 Author Share Posted April 20, 2016 Also can we get a mod to delete this thread? Link to comment Share on other sites More sharing options...
