MBrennan Posted April 10, 2016 Share Posted April 10, 2016 Ive been 2 months waiting for a new motor to be installed. After getting it back ive been getting a cel 2443. Secondary air injection valve bank 2 stuck closed. Ive removed the valve and applied 12 volts to it and it opens to allow air to flow through it. Ive swapped both relays and checked the fuse. Any recommendations where to go from here? Link to comment Share on other sites More sharing options...
apexi Posted April 11, 2016 Share Posted April 11, 2016 Just to double check while waiting for others to reply.. It looks like there are two valves, you tested the driver side valve right? Link to comment Share on other sites More sharing options...
MBrennan Posted April 11, 2016 Author Share Posted April 11, 2016 I applied power to the valve that is under the intake and i could hear the plunger actuating. For what thats worth. Link to comment Share on other sites More sharing options...
apexi Posted April 12, 2016 Share Posted April 12, 2016 It sounds like the one under the intake might be the bank 1 valve. I would check the driver side valve too, I'm pretty sure the driver side is bank 2. M sprank has some pictures in the link below, and I've attached the fsm page with its location. http://legacygt.com/forums/showthread.php/2007-2009-air-pump-delete-cel-codes-and-ecu-fix-140259.html Link to comment Share on other sites More sharing options...
MBrennan Posted April 12, 2016 Author Share Posted April 12, 2016 It sounds like the one under the intake might be the bank 1 valve. I would check the driver side valve too, I'm pretty sure the driver side is bank 2. M sprank has some pictures in the link below, and I've attached the fsm page with its location. http://legacygt.com/forums/showthread.php/2007-2009-air-pump-delete-cel-codes-and-ecu-fix-140259.html I believe that to be correct. That is the valve that i removed and applied power directly to it and it allowed air to flow once i actuated it. I guess what i need to do is hook up a volt meter to the plug that geoes to the valve and verify its actually getting power to actuate it. Part of the problem i have run across is that if the vehicle is at all up to temp the system isnt called on to function. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 12, 2016 Share Posted April 12, 2016 Secondary air pumps are only in place to push air into the exhaust system so that the cats can heat up quicker. They only run for the first 5-10 seconds on cold starts. If you have power and ground at the connector then replace the pump. Link to comment Share on other sites More sharing options...
MBrennan Posted April 14, 2016 Author Share Posted April 14, 2016 I disconnected the outlet pipe from the pump and it comes on and blows air for a few seconds and shuts off. This is with the motor cooled for a couple of hours. I have the wiring disconnected from the drivers side valve with a test light hooked between the pins on the connector. Once it cools down again ill go out and start it to see if the test light illuminates. If it does ill assume the valve is junk. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 14, 2016 Share Posted April 14, 2016 Check for power and ground at the connector. If you can get it to work by applying power, then it's not the pump. You may have a broken wire if the relays and fuse check good. Link to comment Share on other sites More sharing options...
