devilzdriver Posted April 4, 2016 Share Posted April 4, 2016 Hello all! So I just got back from a business trip went and drove my car 2005 LGT. I notice the temp is rising. When I was cruising the temp went down. I get back home thinking the worst. I check coolant. It was low, I put some coolant in, bleed the system all is good. I then notice my res was bubbling.... I then really think the worst. Long story short I put some UV dye in the coolant run the car, got it on the freeway, idled it for over a half hour it was between 190 - 200. I check the res, its bubbling still. I then see a puddle of coolant on the passenger side, on top of the block. Its like the last little piece before its a gap to the turbo. I can see the uv dye / coolant puddle there, I checked everything in the general area. Turbo coolant return, hoses from the turbo coolant tank, nada. Does anyone have an ideas? Or has this happened to them? I am stumped. Link to comment Share on other sites More sharing options...
WahooNo2 Posted April 4, 2016 Share Posted April 4, 2016 there is a hard line that goes from middle or bottom of the block to the turbo attached is a pic i took when i did my clutch a few years ago. it could be that if its rusty. did you replace the turbo recently? Link to comment Share on other sites More sharing options...
devilzdriver Posted April 5, 2016 Author Share Posted April 5, 2016 The turbo / engine are fairly new. About 20k on it. Its such a weird spot to pool coolant because I don't see how it can get there. Ill snap a picture tomorrow when I get home from work. Link to comment Share on other sites More sharing options...
