alexs Posted April 4, 2016 Share Posted April 4, 2016 I just got a 2000 model but there is problem with the power window and the power lock. the driver's seat window is not working but, it is possible to move the other windows from the driver's seat door panel. Also, the power lock is not working neither on the driver's side or the passager. I checked the fuses and they seemed ok. I dont suspect the switches because i can control all the other windows. Do I need to check the window motor at this point? Is there better way to see if the problem is the motor, apart from disassembling the whole door? Link to comment Share on other sites More sharing options...
RumbleRumble Posted April 4, 2016 Share Posted April 4, 2016 Try disconnecting the battery (red post) for 15 mins. The battery could have been dead at some point. Link to comment Share on other sites More sharing options...
