ag3c Posted April 1, 2016 Share Posted April 1, 2016 Greetings! I have an '05 OBXT (2.5T) and recently installed some aftermarket HID lights. While the lights are awesome in every way, I had to disable the DRL circuit to get the HID ballasts to work. I'm not sure if there's any residual debate about the necessity of DRLs, but I do want to restore some aftermarket form of DRLs in the car. I'll of course fuse and relay them etc etc, but what can I use to trigger the relay? I need to tap into some on-when-the-car-is-on wire in the engine bay, or go back through the firewall and find something suitable there. I think I'd prefer the former. Any suggestions? [newbie, first post, please be gentle] Link to comment Share on other sites More sharing options...
mwiener2 Posted April 1, 2016 Share Posted April 1, 2016 On this car the DRL's are simply a low voltage sent to main headlight to make them run at a lower output. It would be fairly difficult to use the existing system to make new DRLs. Want lights on during the day? Turn on your headlights. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
GTEASER Posted April 1, 2016 Share Posted April 1, 2016 Not promoting this particular brand or website, but some aftermarket DRL's come with a control box that senses battery voltage and turns on when the car is running. You just wire it to the battery. Also, I have seen the control boxes separately somewhere that you can wire to your choice of LED lights, maybe TheRetrofitSource has some controllers. http://store.ijdmtoy.com/High-Power-Luexon-LED-Daytime-Running-Lights-p/60-011.htm I am running Sylvania (Osram) LEDriving PX-5 lights. https://www.sylvania.com/en-us/products/automotive/ledriving-kit/Pages/ledriving-px.aspx GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Dispatch20 Posted April 4, 2016 Share Posted April 4, 2016 Greetings! I have an '05 OBXT (2.5T) and recently installed some aftermarket HID lights. While the lights are awesome in every way, I had to disable the DRL circuit to get the HID ballasts to work. I'm not sure if there's any residual debate about the necessity of DRLs, but I do want to restore some aftermarket form of DRLs in the car. I'll of course fuse and relay them etc etc, but what can I use to trigger the relay? I need to tap into some on-when-the-car-is-on wire in the engine bay, or go back through the firewall and find something suitable there. I think I'd prefer the former. Any suggestions? [newbie, first post, please be gentle] I'd just go through the firewall grommet and use the "ACC" fuse in the driver side fuse panel. I actually did exactly what you are trying to do, but on a 3rd Gen Legacy retrofit. My goal was to disable the DRLs when the HIDs turned on, but keep the DRLs on at any other point that the key was On/Run. This mimics the behavior of the stock DRLs. More details about the relay setup in a wiring diagram here: http://legacygt.com/forums/showthread.php/bi-xenon-hid-retrofit-3rd-gen-00-04-legacy-walkthrough-249471.html Link to comment Share on other sites More sharing options...
