Suarezlegacy Posted March 30, 2016 Share Posted March 30, 2016 I've purchased two different turbo oil and water line kits online and both came with 14mm female holes. The vf40 turbo that I purchased requires 12mm female holes with 12mm banjo bolts. I can find the bolts easily but the lines and pipes I have looked everywhere and can't find them and honestly don't even know the proper names for them. I know I'm a noob. But this is the only thing holding me back from getting the car running. I included the link of the kit I bought. The other was kinugawa and was basically the same thing http://m.ebay.com/itm/Turbo-Oil-Water-Line-Install-Gasket-Complete-Kit-For-Subaru-Legacy-TD05-TD06-/322027649992?nav=SEARCH Link to comment Share on other sites More sharing options...
Legacy_Guy Posted March 30, 2016 Share Posted March 30, 2016 http://opposedforces.com/parts/legacy/us_b13/type_12/intake_and_supply_system_turbocharger/turbo_charger/ This has all the part names and part numbers you'll need to order the correct lines and banjo bolts. Link to comment Share on other sites More sharing options...
