TheYonks Posted March 29, 2016 Share Posted March 29, 2016 So I'm in the middle of doing a WRX swap, have the whole drivetrain in the car and bolted up. I pulled my dash today and went to put on the 04 WRX pedal assembly I have from my donor car and the bolts on the top part dont line up with the body. I pulled them back out and put them next to my outback pedals and sure enough the bolts are about a half inch farther away up top. I'm confused though since I've seen multiple build threads where people have swapped them in. Has anyone else ran into this issue? Also, I had bought a 2 core WRX radiator only to find out the other day it is about 2 inches too tall to fit in the engine bay. The top of my hood will hit it. Anyone gotten a WRX radiator to fit in their car or have any clever ideas on how to make it work?, the only thing I can think of is to cut the radiator support bar which I really dont want to have to do. Link to comment Share on other sites More sharing options...
TheYonks Posted March 29, 2016 Author Share Posted March 29, 2016 Well I feel like an idiot. Took a closer look at the wrx pedals and they are just covers, popped them off and put em on my legacy pedals Link to comment Share on other sites More sharing options...
wtdash Posted April 5, 2016 Share Posted April 5, 2016 Hi, AFAIK, all turbo radiators are bigger/taller than NA versions and won't fit. FWIW, I've had 2 turbo swap projects - '90 Legacy and '98 Forester, both of which were tuned for 18Psi and I ran their stock rads w/out issue. If you plan on racing/rallying/etc, then maybe you'll need the bigger unit. edit: go find what Alphius did on is GT>>WRX swap. GL, TD Link to comment Share on other sites More sharing options...
Zerohour Posted April 5, 2016 Share Posted April 5, 2016 I used the 1" core from the oddball outback radiators. They were on 96, 97, 98(?) 2.5 outbacks. I have this on an ej22e with td04l at 6 psi manifold pressure. Held up fine for the 5k I have on the build. The fan shrouds are different, but hook up there same to the wiring. Link to comment Share on other sites More sharing options...
LegGtBK97 Posted April 27, 2016 Share Posted April 27, 2016 What did you end up doing with the rad situation? Link to comment Share on other sites More sharing options...
