Soarin Posted March 29, 2016 Share Posted March 29, 2016 I know I'm starting a new thread, but I'm looking up what is an acceptable loss percentage for our EJ255 and turbo cars. (See my BTSSM says I have knock thread) I'm finding a lot of information and just want to be sure. What is and what isn't okay for leakdown percentages? I've been looking and some sources like NASIOC say anything under 10% is definitely good and healthy. Club WRX says that even up to 20% loss isn't great, but okay. Cylinders 1 through 3 on my LGT have 5% loss and number 4 has 11% loss. Before you ask, compression results were good with 153 to 155 all around. Should I get another one at the dealer to compare with the first batch of results I have? I'm here to learn, so lay it on me. Thanks in advance. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 29, 2016 Share Posted March 29, 2016 under 5% i believe is acceptable. Did they listen to where the 11% went? You can hear if its a intake valve, exhaust, or rings usually if its leaking. Link to comment Share on other sites More sharing options...
Rhitter Posted March 29, 2016 Share Posted March 29, 2016 I know I'm starting a new thread, but I'm looking up what is an acceptable loss percentage for our EJ255 and turbo cars. (See my BTSSM says I have knock thread) I'm finding a lot of information and just want to be sure. What is and what isn't okay for leakdown percentages? I've been looking and some sources like NASIOC say anything under 10% is definitely good and healthy. Club WRX says that even up to 20% loss isn't great, but okay. Cylinders 1 through 3 on my LGT have 5% loss and number 4 has 11% loss. Before you ask, compression results were good with 153 to 155 all around. Should I get another one at the dealer to compare with the first batch of results I have? I'm here to learn, so lay it on me. Thanks in advance. You should take it to a place with a boroscope to visually inspect the results. My OBXT build Link to comment Share on other sites More sharing options...
Soarin Posted March 30, 2016 Author Share Posted March 30, 2016 Thanks for the replies. I've heard Subaru says up to 8% is okay. After that it's no bueno. No, they could not hear where the leak is from on #4. Only that it leaks 11%. I like the boroscope idea. That would be great and I'll ask around to see who does it. Link to comment Share on other sites More sharing options...
