pop-pop Posted March 24, 2016 Share Posted March 24, 2016 My local Subaru shop says I need the following: 1) Replace front left axle -- $315 parts and labor 2) Replace left and right front control arm front bushings -- $497 parts and labor (includes 4-wheel alignment) 3) Replace rear left and right trailing arm front bushings -- $493 parts and labor Ripoff or no? Car has 90k miles and is 11 years old. Does that seem reasonable lifespan for these parts? Thanks a lot. Link to comment Share on other sites More sharing options...
whiteout Posted April 10, 2016 Share Posted April 10, 2016 That sounds like about double what I paid a local garage not quite 2 years ago. I'm not at home to check the file to be sure. I went with polyurethane control arm bushing. The kit from Summit racing was ~ $41 I think. Have them change the seal in the transfer case when you have the axle changed. john Link to comment Share on other sites More sharing options...
Rhitter Posted April 11, 2016 Share Posted April 11, 2016 That sounds like about double what I paid a local garage not quite 2 years ago. I'm not at home to check the file to be sure. I went with polyurethane control arm bushing. The kit from Summit racing was ~ $41 I think. Have them change the seal in the transfer case when you have the axle changed. john I just changed my axel. And I didn't change the seal. No issues. No leaks. I did buy a seal just in case I damaged it though. My OBXT build Link to comment Share on other sites More sharing options...
