Billnyeflyinby Posted March 15, 2016 Share Posted March 15, 2016 https://www.rallysportdirect.com/fits/2005-subaru-legacy-gt-2-5/sway-bars/cus-684-311-a23-cusco-front-sway-bar-23mm Trying to find something new to add to my LGT Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted March 15, 2016 Share Posted March 15, 2016 My whiteline bar made a world of difference in terms of fighting body roll. Of course, my car is almost a foot higher than yours and the factory kyb's are still garbage, but it will definitely help with body roll. Link to comment Share on other sites More sharing options...
Redslaya Posted March 15, 2016 Share Posted March 15, 2016 a rear sway bar would benefit you more if you were doing a single bar. both would obviously be best. one thing to note is you'll want to also upgrade your endlinks when putting on a bigger bar as the stock ones can have trouble and break. if you are doing a rear bar the AVO rear mount braces are highly recommended as a bigger bar can bend or even break off the stock flimsy mounting points Link to comment Share on other sites More sharing options...
Soarin Posted March 15, 2016 Share Posted March 15, 2016 Everything that Redslaya said about the AVO rear swaybar reinforcement brackets is true. Get those so the stock mounts don't bend or break. I have them and they're well worth it. Link to comment Share on other sites More sharing options...
freaksavior Posted March 15, 2016 Share Posted March 15, 2016 Yes. The car handles so much better. The best way to describe it from me is predictable now. It used to understeer, and now it's pretty much on point. I only did the rear with moog endlinks, avo brackets, and a fixed whiteline 22. Link to comment Share on other sites More sharing options...
FJuan Posted March 15, 2016 Share Posted March 15, 2016 No, it makes your car stiff through the corners. Who wants a bumpy corner, I love the way my sways like a boat. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted March 16, 2016 Share Posted March 16, 2016 https://www.rallysportdirect.com/fits/2005-subaru-legacy-gt-2-5/sway-bars/cus-684-311-a23-cusco-front-sway-bar-23mm Trying to find something new to add to my LGT im very pleased with the incremental increase with the jdm. dead on neutral. used all the stock bushings etc that came from factory. no issues thus far after many years. a proper alignment should do you well if you dont have one though Link to comment Share on other sites More sharing options...
grovlet Posted March 18, 2016 Share Posted March 18, 2016 I love mine with Sways/Bushings/Koni Yellows on stock springs!!! It's point and shoot - only problem now is I have to stay off the go pedal as it's hard to really feel the speed when just cruising..... Link to comment Share on other sites More sharing options...
BoyceWare Posted March 26, 2016 Share Posted March 26, 2016 Here's a full parts list front my recent order for my 07 LGT Sedan. Along with my coils this was a huge handling upgrade. Name Model Front Sway Bar BSF30Z Rear Sway Bar BSR39Z Front End Links KLC139 Rear End Links KLC144 AVO Brackets S1104M1HT001T Link to comment Share on other sites More sharing options...
