YeuEmMaiMai Posted March 14, 2016 Share Posted March 14, 2016 well I am doing brakes and I need to know if I can substitute a regular caliper pin for the one that has the rubber on it. if all this is for is noise reduction I can live without it. the rubber has swollen and prevents free pin movement. Thanks Link to comment Share on other sites More sharing options...
RumbleRumble Posted March 15, 2016 Share Posted March 15, 2016 It could jam, you can get a brake hardware kit at any local parts store for less that 20$ that comes with new slide pins w/boots and bolts. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 15, 2016 Author Share Posted March 15, 2016 I know that, what I am asking is can I just use a regular caliper pin? on the bracket there is no physical difference between the holes and the pins are the same size and the rubber pin will easily fit in either hole. I am trying to avoid the rubber swell and jam my caliper part. Link to comment Share on other sites More sharing options...
