mestizoracer310 Posted March 12, 2016 Share Posted March 12, 2016 I want independent control of the fog lights but still have them turn off when I turn the key off....in the event I'm in a rush and forget to turn the switch off manually. I've made extensions for the OE relay, using a female spade connector with a very short piece of wire ending with a male spade connector... On the last relay terminal I was going to just use a longer piece of wire and tap into a switched 12v source somewhere....or just do like I did on my 02 acura tl.....use one of those add a circuit and do it at the fusebox.... Not sure which is the cleanest and safest route.... Link to comment Share on other sites More sharing options...
battelready Posted March 14, 2016 Share Posted March 14, 2016 http://legacygt.com/forums/showthread.php/100-independent-foglight-mod-no-wire-cutting-splicing-method-35066.html This should help. If you search it up , theres many ways to do it. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
mestizoracer310 Posted March 14, 2016 Author Share Posted March 14, 2016 The tablet I use doesn't allow me to search on this site, truly annoying. Anyway, thread you linked me to seems like way too much work. All I thought was to just connect ignition voltage to power the relay, via an add a circuit..... Link to comment Share on other sites More sharing options...
