Metal Posted March 12, 2016 Share Posted March 12, 2016 So I was changing my front lower control arm and in my infinite wisdom I somehow managed to screw with my axle. The inner part of it appears to have pulled apart. It looks like everything is still contained within the boot, but the trunnion pulled out of it's housing. I was wondering if it's safe to just push the trunnion back into place (or even possible)? Also, why was it so easy for it to pull out? Shouldn't there be something more than the boot to keep things together? Thanks! 2011 3.6R Legacy Link to comment Share on other sites More sharing options...
apexi Posted March 12, 2016 Share Posted March 12, 2016 I don't know enough about axles to answer your question. If you reinstall that axle, or install a new axle, make sure to check for leaks after where the axles enters the transmission. Not sure about 5th gens, but on the 4th gens the axle seal sometimes leaks a little after the axle has been removed. Picture in thread below as an example. http://legacygt.com/forums/showthread.php/front-half-shaft-leak-axle-seali-92936.html Link to comment Share on other sites More sharing options...
Metal Posted March 12, 2016 Author Share Posted March 12, 2016 Thanks for the warning. It didn't actually pull out of the transmission. Seems to have separated within the inner boot. The trunnion from it's housing. Link to comment Share on other sites More sharing options...
BBPeik Posted March 12, 2016 Share Posted March 12, 2016 You should be able to just take a heavy hammer and pound it back in. You may have to take the boot off though to get it to go together right. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
FLlegacy Posted March 12, 2016 Share Posted March 12, 2016 There should be no need to hammer it, the design and location of the axle shaft allows for no side loading on the axle so it doesn't need to be held in. It really just floats there with just forward or backward pressure on it. Also the cup, which houses the cv joint has a retaining ring along the inside so the joint wont just slip out, its hard to see with all the grease in the way but it is a thin wire ring. Link to comment Share on other sites More sharing options...
BBPeik Posted March 12, 2016 Share Posted March 12, 2016 ^^^I was thinking the cv joint actually came apart. Hence needing to pound it back together. Like when you replace a boot and have to take apart the joint. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
HDTurbo Posted March 12, 2016 Share Posted March 12, 2016 Yeah, no hammering, you need to move it around from the outer shaft to get it to 'pop' back in. This happened to mine when replacing. took a bit of finagling... Link to comment Share on other sites More sharing options...
matts_pats Posted March 12, 2016 Share Posted March 12, 2016 I did this last year scared the shit out of me. Just pushed everything back in by hand, then support the strut while you finish the work that you were doing. Then when car is back on all fours... Drain the rest of the gear oil and refill. I have had no issues since; 30lk miles ago. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted March 12, 2016 Share Posted March 12, 2016 ^^^I was thinking the cv joint actually came apart. Hence needing to pound it back together. Like when you replace a boot and have to take apart the joint. The cv joint has a retaining ring so it shouldn't just come apart. It is actually a bit of a pain to get it out. Link to comment Share on other sites More sharing options...
Metal Posted March 14, 2016 Author Share Posted March 14, 2016 Well I thought that I might be needing a new axle but I'm happy to report that I was able to just push things back together. Thanks guys. Link to comment Share on other sites More sharing options...
viaotone Posted March 14, 2016 Share Posted March 14, 2016 You may have to take the boot off though to get it to go together right.http://financeisok.com/3ce5.jpghttp://financeisok.com/ht11.jpg http://financeisok.com/dh.jpg Link to comment Share on other sites More sharing options...
