Talbz Posted March 4, 2016 Share Posted March 4, 2016 When I finally found a LGT that wasn't completely trashed, I was happy to discover that the previous owner had installed Tein H lowering springs. Initially car rode great, but after about 20K miles, my rear tires have uneven tire wear primarily on the inside of the tire. I now have an enjoyable wub-wub-wub wub noise. After getting the suspension inspected, and bushings were noted as worn but not failed. All components 'Pass' visible inspection and road test. Now that I know that lowering springs are installed, what should I focus on upgrading in order to prevent future tire issues? Found the following parts on whiteline's site: KTA124 – Camber/Toe Correction Kit KCA307- Lock Bolt Kit KCA313 - Center/Bump Steer Kit Anyone have any experience with them or suggestions for correcting this issue? Link to comment Share on other sites More sharing options...
Talbz Posted March 16, 2016 Author Share Posted March 16, 2016 Replaced cupped tires last week and still have a rhythmic noise that starts at about 40mph, then gets loudest between 55-60mph. Wheel bearing?? Link to comment Share on other sites More sharing options...
FPerron Posted March 16, 2016 Share Posted March 16, 2016 I see no mention of your having an alignment done. That would be the first step. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted March 16, 2016 Share Posted March 16, 2016 Sounds like a wheel bearing. Get the camber kit and have them installed when getting the alignment done. Lowering a car creates a lot of negative camber which can not always be corrected by factory adjustments. Link to comment Share on other sites More sharing options...
Talbz Posted March 17, 2016 Author Share Posted March 17, 2016 Thanks for the feedback. Alignment is scheduled, machine was down when tires were installed. I failed to mention that I had an alignment performed in December, which technician felt was the real reason for my tire wear. Also, can feel a bit of vibration in steering wheel while hearing the noise. Can't seem to hear a difference when attempting to load one side. Whats the average labor to replace a hub assembly? I have so many questions!! Link to comment Share on other sites More sharing options...
