Ken Posted July 27, 2004 Share Posted July 27, 2004 Been driving our GT Wagon for a few days now and I have found that the EBD kicks in often and early. It feels like ABS but I'm not braking hard enough to cause any lockup. Its a very disconcerting feeling. The manual does mention this and that it is normal. I'm sure its working as designed since it starts up while decelerating in turns before the apex. Is anyone else engaging this system regularly? Or am I just an aggressive driver? :wink: Link to comment Share on other sites More sharing options...
KayGT Posted July 27, 2004 Share Posted July 27, 2004 you're just an agressive driver. Link to comment Share on other sites More sharing options...
SUBE555 Posted July 27, 2004 Share Posted July 27, 2004 You on RE92's? Might explain that. I have only done a few hard braking situations with my GT and never felt it, then again, mine has upgraded tires. And the stick! Link to comment Share on other sites More sharing options...
AreEyeSeeKay Posted July 29, 2004 Share Posted July 29, 2004 What is the feeling that you are experiencing? The way I understood EBD it is just a dynamic break pressure apportionment, as opposed to a static "one size fits all" setting from the factory. I only imagined this would come in to play if you were towing, or had a heavy load in the car. Link to comment Share on other sites More sharing options...
Ken Posted July 29, 2004 Author Share Posted July 29, 2004 The brake pedal pulsates very quickly and lightly similar to the ABS feeling. The brakes are cross connected from rear to opposite front. It supposed to kick in whenever there is detected slippage. This should be most evident in turns when you understear in and the inside rear lightens up. Its supposed to be for performance, not towing. I think its just something I need to get used to, cause I'm not gonna slow down... Link to comment Share on other sites More sharing options...
