sirstinky Posted January 30, 2016 Share Posted January 30, 2016 Hi all. A bit of a head-scratcher for you guys. :confused:I took the plunge and bought a Bluetooth scan tool. I got it to originally diagnose a P0420 and clear the code to see if it would come back and to check the 02 sensor function to see if the cats are bad or it's a bad sensor or something else. Well I am having some confusion as to which 02 sensors the scan tool is reading. (see the pictures). One is "02 sensor 1 wide-range voltage" and "02 volts Bank 1 sensor 2." The values for them don't make any sense. The first one reads on average 1.3-1.5 volts (it fluctuates) and has gone up to almost 2 volts (way too high). The second sensor is a little more "normal" it reads under 1 volt consistently but also bounces around. It's confusing because they seem to read higher than they should? Why is there no value for "02 volts Bank 1 Sensor 1"? I ran a graph of live data and it shows pretty much the same. Under 2000 rpm's the wide-range sensor goes all over the place rich-lean and the other sensor acts like it should for a downstream sensor, fluctuating slowly and consistently. I hooked the tool to my wife's car (Ford Escort) and the sensors seem to be in order (bank 1 sensor 1, bank 1 sensor 2). Is this a Subaru-specific deal? Anyone else seen this before? Thanks! Link to comment Share on other sites More sharing options...
kewshi Posted February 1, 2016 Share Posted February 1, 2016 I have the same app and when I do a graph of my o2 sensors for my 02 legacy sedan I can only find 1 o2 sensor I think it came up b1 s2 do you have 2 that show up in torque? Link to comment Share on other sites More sharing options...
allmightyfork Posted February 2, 2016 Share Posted February 2, 2016 Is the p0420 cat code the only dtc? From the data i see the o2's seem fine. Generally when a sensor goes bad you will have codes for them.( Usually it will be a circuit code) Link to comment Share on other sites More sharing options...
sirstinky Posted February 3, 2016 Author Share Posted February 3, 2016 Thanks. Yes that was the only code. I cleared it 2 weeks ago and it hasn't returned. Crossing fingers. I did a graph of sensor data and they seem to be in line with a normally functioning catalyst. The only anomaly is the upstream o2 sensor that reads up to 2 volts at times. I'll keep an eye on it and is it comes back and the sensors are fine then I can condemn the cats! Link to comment Share on other sites More sharing options...
sirstinky Posted February 3, 2016 Author Share Posted February 3, 2016 I have the same app and when I do a graph of my o2 sensors for my 02 legacy sedan I can only find 1 o2 sensor I think it came up b1 s2 do you have 2 that show up in torque? Yah it's weird. I show 3 o2 sensor PIDs. One is the "equivalence ratio" and the other two are the actual sensor. I assume the o2sltv in mine is the upstream sensor and the b1s2 is the downstream (post cat). I'm not sure if it's a Torque-specific deal for Subaru's or its like that for all vehicles. Link to comment Share on other sites More sharing options...
