blough Posted January 28, 2016 Share Posted January 28, 2016 I am considering a built 5EAT this summer for a 350-400awhp build. I have a 2008 LGT and I was wondering what the Pros/Cons of a built trans would be. I also want to find out how much it will cost me. Link to comment Share on other sites More sharing options...
whitrzac Posted January 28, 2016 Share Posted January 28, 2016 It can not be done on the 08-09 cars. Link to comment Share on other sites More sharing options...
blough Posted January 29, 2016 Author Share Posted January 29, 2016 Oh no that's not what I wanted to hear. I guess I'll have to keep her in the 300 range. Link to comment Share on other sites More sharing options...
NSFW Posted February 2, 2016 Share Posted February 2, 2016 What can be done on the 05-06 cars? Link to comment Share on other sites More sharing options...
starionesir Posted February 2, 2016 Share Posted February 2, 2016 You can upgrade the valve body, add clutches and other various things. Not available on the later models. Link to comment Share on other sites More sharing options...
apexi Posted February 8, 2016 Share Posted February 8, 2016 I would look at ClimberD's links in the thread below.. From what I have read he seems like the go to guy for 5EAT's. http://legacygt.com/forums/showthread.php/climberds-hexmods-diary-165161.html Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 12, 2016 Share Posted February 12, 2016 I am considering a built 5EAT this summer for a 350-400awhp build. I have a 2008 LGT and I was wondering what the Pros/Cons of a built trans would be. I also want to find out how much it will cost me. Without a solution to increase your 5eat line pressure, you'll burn up your clutch packs pretty fast with 350+ whp. There are things you can do to help your situation, tuning workarounds, internal trans builds, fluid coolers, which will all help a lot. Driving style will make a huge difference too. But at the end of the day you'll have a lot of torque and not enough trans line pressure to hold your clutch packs engaged tightly. People have still done it, but it's a heck of a compromise. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
blough Posted February 13, 2016 Author Share Posted February 13, 2016 Thank you for the advice ClimberD, I think im going to shoot for 300-320awhp. I will be doing trans cooler/bushings/etc. Still have a lot to learn about these 5EAT's. Link to comment Share on other sites More sharing options...
jayrex Posted February 19, 2016 Share Posted February 19, 2016 Without a solution to increase your 5eat line pressure, you'll burn up your clutch packs pretty fast with 350+ whp... I took a quick look through a bunch of your threads Climber, and didnt see anything about line pressure. I have an 05 - 5eat, are you saying there is a way to increase the line pressure on that year? Do you have a thread link to that info? My aging trans is slipping bad in 3rd, 4th, and 5th. Link to comment Share on other sites More sharing options...
starionesir Posted February 19, 2016 Share Posted February 19, 2016 jayrex do you have his upgraded valve body? If so I believe with his mods it ups the line pressure. If you don't have a upgraded valve body I would highly recommend one. Sadly it won't fix a slipping transmission though. Sounds like a rebuild or new transmission is gonna be needed sooner then later. Link to comment Share on other sites More sharing options...
jayrex Posted February 19, 2016 Share Posted February 19, 2016 Thanks Starionesir, this clears up a missing link for me. I planned on installing the VB mod while I get the clutch packs replaced (very soon). I just didn't know line pressure was the result of the mod. Makes perfect sense really. =P Slipping started right after a JMP turbo upgrade and etune. The gears just kinda fell like dominoes after that... 5th, 4th, then 3rd. They all still work, but I can break them free easily with about 60% throttle. Can't wait til this is not the 'weak link' anymore. Thanks again for the reply. Sorry to thread jack a bit there Blough, your goals are quite similar to mine. Sorry there is no VB mod for yours... yet/ever? =( Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 22, 2016 Share Posted February 22, 2016 I took a quick look through a bunch of your threads Climber, and didnt see anything about line pressure. I have an 05 - 5eat, are you saying there is a way to increase the line pressure on that year? Do you have a thread link to that info? My aging trans is slipping bad in 3rd, 4th, and 5th. I've mentioned it many times, but there are hundreds if not thousands of posts on transmission modifications from me, would take days to get through, and probably not a great use of time to read the earlier ones where I was still figuring everything out for myself. Yes lines pressure is THE key to increased clutch pack grip in the 5EAT where it is quite low from the factory due to low factory torque relative to what people are getting with tunes and modifications. Thanks Starionesir, this clears up a missing link for me. I planned on installing the VB mod while I get the clutch packs replaced (very soon). I just didn't know line pressure was the result of the mod. Makes perfect sense really. =P Slipping started right after a JMP turbo upgrade and etune. The gears just kinda fell like dominoes after that... 5th, 4th, then 3rd. They all still work, but I can break them free easily with about 60% throttle. Can't wait til this is not the 'weak link' anymore. Thanks again for the reply. Sorry to thread jack a bit there Blough, your goals are quite similar to mine. Sorry there is no VB mod for yours... yet/ever? =( If you're going to do a rebuild soon for sure, then do that and make sure it was all done 100% correctly before installing the valve body upgrade. This is very important advice. However, if your goal is to try to milk it for another 10,000 miles, or however long you can, then you would: 1) Install HexMods F1. 2) Replace fluid with new Amsoil ATF. 3) Install a transmission fluid cooler (should do this regardless, no matter what). 4) Toss in a small bottle of Lucas Transmission Fix for Autos. It won't hurt anything, and it could make a noticeable difference on a transmission as fried as yours. Some customers have done this and gone literally years more before having to replace the transmission. But it really depends on the condition of the clutch packs. They could be soso but slipping due to all the extra torque, or they could just be cooked and slipping because they have little or nothing left to give. If they are completely cooked, then putting an F1 on it would just make your slipping more sporty Happy to help, it's what I do [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Mike07LGT Posted February 23, 2016 Share Posted February 23, 2016 Thank you for the advice ClimberD, I think im going to shoot for 300-320awhp. I will be doing trans cooler/bushings/etc. Still have a lot to learn about these 5EAT's. Yea you'll learn quickly that 5 or 6mt is the way to go 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
whitrzac Posted February 23, 2016 Share Posted February 23, 2016 Yea you'll learn quickly that 5 or 6mt is the way to go But how will I eat breakfast and do my makeup while making you eat my dust? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 27, 2016 Share Posted February 27, 2016 But how will I eat breakfast and do my makeup while making you eat my dust? Steering with left knee, accelerating WOT with right foot, breakfast with left hand, makeup with right hand (using sun visor mirror), mocha with long straw. What could possibly go wrong. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
whitrzac Posted February 27, 2016 Share Posted February 27, 2016 Steering with left knee, accelerating WOT with right foot, breakfast with left hand, makeup with right hand (using sun visor mirror), mocha with long straw. What could possibly go wrong. Funny you bumped this tonight... There was a cobalt SS tonight that thought he was hot stuff. I was eating an ice cream cone:lol: Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 27, 2016 Share Posted February 27, 2016 You are brave to eat ice cream in a car! Cobalt SS is an interesting platform. I realize 99% of them are slow, but there are a bunch out there making more power than anyone with a LGT ever has, for a lot less money. From a roll it would be a bad day. Any kind of launch or turn or breaking though, yeah Funny you bumped this tonight... There was a cobalt SS tonight that thought he was hot stuff. I was eating an ice cream cone:lol: [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
762x39 Posted February 28, 2016 Share Posted February 28, 2016 Lets not forget about those rev-happy SRT-4 Neon Douches! In my area they are a special type of ricer-retarded and they sound even worse than Hondas. Link to comment Share on other sites More sharing options...
Thinking out side box Posted March 30, 2016 Share Posted March 30, 2016 I would use Hexmods F2 style instead , it holds up better to the boost. Link to comment Share on other sites More sharing options...
