highwind Posted January 14, 2016 Share Posted January 14, 2016 Im looking at buying these rims if they would fit they are 18"x8" TSW Vortex rims in hyper silver with Yokohama SDrives 225/40r18. Bolt pattern is 5x100 offset +35?? I have stock suspension on my 09 3.0R thanks Link to comment Share on other sites More sharing options...
I3eXa Posted January 14, 2016 Share Posted January 14, 2016 stock TSW Diameter 625.3mm 637.2mm Circumference 1964.4mm 2001.8mm Poke 33.9mm 66.6mm Inset 143.9mm 136.6mm Speedo error 0% -1.87% Reading at 30mph 30mph 29.44mph Reading at 60mph 60mph 58.88mph Ride height gain 0mm 5.95mm Arch gap loss 0mm 5.95mm gonna poke out quite a bit more. willtheyfit.com Link to comment Share on other sites More sharing options...
highwind Posted January 14, 2016 Author Share Posted January 14, 2016 damn that sucks but thanks for the info Link to comment Share on other sites More sharing options...
Andy_Mac Posted January 17, 2016 Share Posted January 17, 2016 Its not that they are completely impossible to fit, they will only poke out 5.6mm more than mine. I have rear camber bushes set at about 1.5degrees and get zero rubbing even with the boot fully loaded. Haven't had the fenders rolled either so that alone should in theory give you the 5.6mm difference. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
