Cup_of_Joe Posted January 11, 2016 Share Posted January 11, 2016 When I start the car, and let up the clutch and let it warm up, I hear a high pitch whining. I can push the clutch pedal in like half an inch and its not as loud, halfway in and it makes a different noise, all the way in and its quiet. Am I looking at clutch disc etc job. Or is it something with the pedal itself? Maybe fluid? Or god forbid actual transmission. 2010 Legacy 2.5i Base, Manual, 93k Miles, After market exhaust. Also have not noticed any loss of power or slippage. Sent from my LGLS990 using Tapatalk Link to comment Share on other sites More sharing options...
Byll Posted January 11, 2016 Share Posted January 11, 2016 Well COJ, it sounds like your issue could be the throw out bearing. At 93K, it would be what I would look at first. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted January 11, 2016 Author Share Posted January 11, 2016 DIY job? Driveway with jacks? I've only done a clutch in an 83 rx7, took all day, but seems straight forward. Sent from my LGLS990 using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted January 11, 2016 Share Posted January 11, 2016 You have a couple options either remove the engine or remove the trans. However, if you remove the trans you will need to support the engine inside the engine bay with a special hoist. Personally I would buy a clutch kit, and remove the engine. Its not terribly hard and most of the work is done from the top. At your mileage you might as well do it all, for the amount of work it will take to get to the parts. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted January 11, 2016 Author Share Posted January 11, 2016 That was my next question, should I also do the clutch or any other parts in there I should replace while I'm at it. Sent from my LGLS990 using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted January 11, 2016 Share Posted January 11, 2016 Instead of the TOB that might come with the clutch kit you decide on, get the TSK-3 kit with TOB, it'll protect your snout, and I have been told the TOB with that kit is larger with more material (so hopefully that translates to longer life) My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted January 11, 2016 Share Posted January 11, 2016 Yes, the TSK kit has a better TOB in it, the Subaru ones are crap. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FLlegacy Posted January 11, 2016 Share Posted January 11, 2016 I noticed a ticking after my car sat for a couple days what are the odds it was the TOB? Gonna start planning for my own clutch change. Part number for the TSK kit? Link to comment Share on other sites More sharing options...
Zee199969 Posted January 11, 2016 Share Posted January 11, 2016 I noticed a ticking after my car sat for a couple days what are the odds it was the TOB? Gonna start planning for my own clutch change. Part number for the TSK kit? I dont know the exact part# if there is one but the TSK-3 will fit our cars. I got my from fredbeans before they went off the grid My "Build" Link to comment Share on other sites More sharing options...
Shadow_419 Posted January 11, 2016 Share Posted January 11, 2016 When I start the car, and let up the clutch and let it warm up, I hear a high pitch whining. I can push the clutch pedal in like half an inch and its not as loud, halfway in and it makes a different noise, all the way in and its quiet. Am I looking at clutch disc etc job. Or is it something with the pedal itself? Maybe fluid? Or god forbid actual transmission. 2010 Legacy 2.5i Base, Manual, 93k Miles, After market exhaust. Also have not noticed any loss of power or slippage. Sent from my LGLS990 using Tapatalk Is this an everyday/all day thing? I wouldn't worry too much if it's only for a minute or so when you first start the car. Link to comment Share on other sites More sharing options...
GTEASER Posted January 11, 2016 Share Posted January 11, 2016 I get a TOB squeal every once in a while, and its been happening more the last year or so since my car hasn't been on primary transportation duty. It started at about 30k miles and I have a little over 50k miles on the stock clutch. Like I said, it only happens once in a while. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted January 11, 2016 Author Share Posted January 11, 2016 Mine usually whines at a cold start, I don't notice after I've driven where I needed to or the rest of the day, but I never actually listened for it after the cold start. I'll do some more listening tomorrow. Sent from my LGLS990 using Tapatalk Link to comment Share on other sites More sharing options...
Ellesedil Posted January 12, 2016 Share Posted January 12, 2016 I dont know the exact part# if there is one but the TSK-3 will fit our cars. I got my from fredbeans before they went off the grid I ordered mine through Infamous... which pretty much just forwarded me one from Fredbeans. Link to comment Share on other sites More sharing options...
