Nosneros Posted December 30, 2015 Share Posted December 30, 2015 I have a 2005 Legacy gt AT and whenever I turn on the cruise it starts flashing, I do not have a check engine light. I have talked to a lot of people and I would rather not just throw money at it and actually find the issue. Any help is appreciated. Link to comment Share on other sites More sharing options...
762x39 Posted December 30, 2015 Share Posted December 30, 2015 Even though you have no CEL, you may still be able to pull a code. I would just start by scanning it, many auto part stores will scan CEL's free of charge. Link to comment Share on other sites More sharing options...
Nosneros Posted December 30, 2015 Author Share Posted December 30, 2015 Ill try that and report back on here, im sure this has happened to a lot of people. Link to comment Share on other sites More sharing options...
762x39 Posted December 30, 2015 Share Posted December 30, 2015 In the past when that happened to my car, a CEL usually showed up a day or two later. Kind of like the sniffles before a cold.. Link to comment Share on other sites More sharing options...
KoolAidMan26 Posted February 9, 2016 Share Posted February 9, 2016 It's most likely an issue with a wheel bearing. The sensors for the cruise rely on them. This is a common symptom when someone replaces our front wheel bearings with a cheaper brand. Unfortunately we are stuck with either buying OEM, Timken, or i forgot what other brands work in the front. There is a thread on this somewhere. Well this is also having a symptom of feeling the speed "oscillate" when cruise is engaged for the short period. Link to comment Share on other sites More sharing options...
