Jeremy969 Posted December 28, 2015 Share Posted December 28, 2015 Looking to buy and swap in a TD06. Apparently I posted in the wrong sub section. Excuse me for that. Anyway. 93 SS would like to put a TD06 in. Curious on what needs to be done. Is it a direct fit? Different injectors to support the bigger turbo? Not entirely sure what had been done already but any extra info is great. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
wtdash Posted December 29, 2015 Share Posted December 29, 2015 Hi, FYI - Please make a useful title, w/each new post. INFO is avl. over on legacy central too. I don't think that Gameboy is a 'tuner', but more for logging/monitoring. It sounds like THIS on legacy central: http://bbs.legacycentral.org/viewtopic.php?t=34777 The TD06 is WAY too big for a stock install on Legacy SS/EJ22T. It's intake is likely the bigger 3" and won't work w/your stock pieces, it requires bigger injectors, different MAF, intercooler, and TUNING to make it work. And I wouldn't buy an Ebay TD0-anything. Since I don't know what, if anything you've already done to your SS, it makes it harder to recommend what path to take. Generally, a TD04 and TMIC are about all you can do w/the stock injectors and MAF. Read up on the Rob Tune on Legacy Central for the best bang for the buck. EDIT: If you're putting this in the car on the previous post.....this may be less useful. TD Link to comment Share on other sites More sharing options...
