BOXRPWR Posted September 29, 2005 Share Posted September 29, 2005 WTF? Driving home tonight. Completely casual. About 80 mph on the highway. Totally out of boost. Suddenly the CEL goes on and Cruise control light blinks. I know that's not a good thing. Fortunately, just a couple of miles from home. Get out the AP to read the CEL code. Damn thing displays "No Error Code Found". WTF? Tried it a couple of times with the same result. Used the AP to clear out the CEL. No more miles driven yet. Will watch it closely on the drive to work tomorrow morning. Any ideas??????? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 29, 2005 Share Posted September 29, 2005 AP doesn't read all codes- you might have to go to Autozone, et al. to get some codes read. Link to comment Share on other sites More sharing options...
MarcusDubya77 Posted September 29, 2005 Share Posted September 29, 2005 Actually, the newer AP firmware reads all CELs according to CObb. You might need to send in your AP to get the new firmware..My car did the same thing and my AP was running 1.0 firmware..It appears as the AP powers up. :woowoo:check out the Diamond Gray Metallic Monster!!! Link to comment Share on other sites More sharing options...
D-2.5-GT Posted September 29, 2005 Share Posted September 29, 2005 No need to go to Autozone...there are some wires up inside the fuse panel on the drivers side. You plug them in, one male, one female, white plugs and press the trip reset during the gauge sweep and it will give you the error code thrown right on the gauge panel. I've already had to use it twice to pull codes in the last few weeks before i got the car fixed. Search for the post...its on here somewhere..."Gauge cluster is also OBD reader" Link to comment Share on other sites More sharing options...
BOXRPWR Posted September 29, 2005 Author Share Posted September 29, 2005 That's a cool trick. Guess that I shouldn't have reset it so quickly. Nothing happened on the 45 mile drive into work this morning. If it does happen again, I'll use the "built-in" OBD reader trick. Thanks guys! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 29, 2005 Share Posted September 29, 2005 Actually, the newer AP firmware reads all CELs according to CObb. You might need to send in your AP to get the new firmware..My car did the same thing and my AP was running 1.0 firmware..It appears as the AP powers up. Didn't realize that- can we update the firmware online? Link to comment Share on other sites More sharing options...
MarcusDubya77 Posted September 30, 2005 Share Posted September 30, 2005 Actually there is a return form that Cobb can send via email and you mail the AP to them for the upgrade. :woowoo:check out the Diamond Gray Metallic Monster!!! Link to comment Share on other sites More sharing options...
