dvrpd Posted December 21, 2015 Share Posted December 21, 2015 :confused:I have a 1990 legacy fwd auto with 57,000 miles bought as winter project. got the rear brakes unlocked,(rear praking shoes). the car sat for 2 years. When I went to drive the sub it seems not to start out in first gear and won't stay in fourth gear(overdrive). seems to go between 3 and fourth over and over even when car is warmed up. I changed fluid changed inline filter. I checked trans codes and get a 33 which is speed sensor voltage. would this cause my shifting problems? what do I do next Dave;) Link to comment Share on other sites More sharing options...
wtdash Posted December 23, 2015 Share Posted December 23, 2015 Hi, Read THIS about how to clear the codes, to ensure the same one comes back. You MUST have a working Speedo for the car to run properly. Common issue is for the mechanical sensor for the speedo cable to break where ti connects to the transmission. this Vid - - will give you an idea...the video shows an electronic sensor - yours will be mechanical but they interchange. Td Link to comment Share on other sites More sharing options...
