jersey LGT Posted December 19, 2015 Share Posted December 19, 2015 05 LGT, manual trans with immobilizer. Went out to my car yesterday morning and found that my ignition key pretty much free wheels in the cylinder. I took the ignition switch off the back side and found the problem. The T shape piece of metal that turns the switch, that looks like it's connected to the backside of theq key cylinder, broke off. I can't seem to find any info on whether the key cylinder comes out of the housing or not. Any of the cars I've worked on have all had a release to remove the key cylinder, but I can't seem to find anything. I have an account All Data and there is no procedure on how to remove it. Has anyone changed this before, is it serviceable or do I need to buy the entire housing with new keys? I can take pictures later if anyone is confused on what I'm talking about. Any info is much appreciated. Sent from my SAMSUNG-SM-G928A using Tapatalk Link to comment Share on other sites More sharing options...
jersey LGT Posted December 22, 2015 Author Share Posted December 22, 2015 05 LGT, manual trans with immobilizer. Went out to my car yesterday morning and found that my ignition key pretty much free wheels in the cylinder. I took the ignition switch off the back side and found the problem. The T shape piece of metal that turns the switch, that looks like it's connected to the backside of theq key cylinder, broke off. I can't seem to find any info on whether the key cylinder comes out of the housing or not. Any of the cars I've worked on have all had a release to remove the key cylinder, but I can't seem to find anything. I have an account All Data and there is no procedure on how to remove it. Has anyone changed this before, is it serviceable or do I need to buy the entire housing with new keys? I can take pictures later if anyone is confused on what I'm talking about. Any info is much appreciated. Sent from my SAMSUNG-SM-G928A using Tapatalk Hopefully this helps others who may have a similar issue. I took the cylinder housing off the column to get a better look at it. First off, All Data wants you to pull the column to remove it because the bolt heads are smooth. I ground down the bracket with a dremel and used a turbo socket to take them out with the column in the car. Once I got it out, I could tell the key cylinder isn't serviceable. I blasted out the roll pins and damaged it all but I wanted to see the part that broke. This is what I found. The top "T" part is what broke off and it's what drives the ignition switch. Again, it's not serviceable so I had to order a whole new key set with the new lock cylinder. Sent from my SAMSUNG-SM-G928A using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 23, 2015 Share Posted December 23, 2015 thanks for posting. How much did it cost you? Will you have to reprogram for the immobilizer? Link to comment Share on other sites More sharing options...
jersey LGT Posted December 24, 2015 Author Share Posted December 24, 2015 It cost me $309 for the whole set, but that was my cost as my shop has an account with this Subaru dealer. And I'll probably wind up paying a mobile auto tech $100 for the reprogramming. Sent from my SAMSUNG-SM-G928A using Tapatalk Link to comment Share on other sites More sharing options...
