SnarlyMarley Posted September 29, 2005 Share Posted September 29, 2005 Read alot of good write ups searching around but here is my problem: The lower bolt for the rear struts. I tried an impact gun, a breaker bar, torching the nut and using a short ratchet with a floor jack to get these bolts free with the car just up on jack stands and they wouldn't budge. Any sure fire tricks to get enough brute force to loosen these? I am in Western CT are if anyone wants to recommend a cheap place to get it done... Thanks! James Link to comment Share on other sites More sharing options...
Xenonk Posted September 29, 2005 Share Posted September 29, 2005 it's a locking nut, it's about 350 lbs of initial torque that you gotta put in to break the nut's hold on the bolt. Use a 4' long breaker bar, that will do it. Keefe Link to comment Share on other sites More sharing options...
evil_O Posted September 29, 2005 Share Posted September 29, 2005 Just had this issue. The other thing that will help.. if you have another set of hands... is having someone hold down the other side - pushing the opposite way - with a wrench. Once we did that... it was infinitely easier. Link to comment Share on other sites More sharing options...
rodan Posted September 29, 2005 Share Posted September 29, 2005 I used a breaker bar and floor jack to break them loose, then a breaker bar from there. Something else you'll need to know. If you have the suspension hanging loose, you will need to raise it a little (with a jack) to get the weight off the bolt to pull it out. All in all, this bolt was the hardest part of the whole spring R & R... Link to comment Share on other sites More sharing options...
scans007 Posted September 29, 2005 Share Posted September 29, 2005 I used a breaker bar and floor jack to break them loose, then a breaker bar from there. Something else you'll need to know. If you have the suspension hanging loose, you will need to raise it a little (with a jack) to get the weight off the bolt to pull it out. All in all, this bolt was the hardest part of the whole spring R & R... +10 Link to comment Share on other sites More sharing options...
Xenonk Posted September 29, 2005 Share Posted September 29, 2005 my definition of a "breaker" bar is going to home depot and buy a 2" dia. 4' long iron pipe as my "extension" to the ratchet.. works every time. Just have to get the car up high enough to use it. Keefe Link to comment Share on other sites More sharing options...
abakja1 Posted September 30, 2005 Share Posted September 30, 2005 I held the socket end over the nut and my cuzn started kicking at the wrench,..that shocked that thing off after I had it soaking in PB Blast,.. Link to comment Share on other sites More sharing options...
