StickyBL6 Posted December 10, 2015 Share Posted December 10, 2015 Hello, i reccently purchased a used 22mm Perrin RSB and it didnt come with bushing or mounts. I know I can use my factory mounts but I was told to use the AVO Rear Stabilizer Mount Brace (item number: S1104M1HT001T) with AVO bushings or Whiteline. my question is what would you recommend using for the mounts.. should I get the AVO or stay with the stock mounts and just use aftermarket bushing? I'm trying to figure out what i need/should get before I mount my RSB, Any advice is helpful. Thanks -Josh Link to comment Share on other sites More sharing options...
pseank Posted December 13, 2015 Share Posted December 13, 2015 The stock mount is flimsy. If you need the bar then you need the support. I assume you plan aggressive driving so get the mounts. They are nice pieces. Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
whitetiger Posted December 14, 2015 Share Posted December 14, 2015 the stock mounting points are so weak, even the stock bar could use reinforcement. also the stock U-brackets are garbage too, of if your bar does not come with new ones and you have to re-uses the OEM, get energy suspension universal bushings and u-brackets instead. they will last forever. Link to comment Share on other sites More sharing options...
DugsSin Posted December 15, 2015 Share Posted December 15, 2015 I went with the AVO's with no complaints. Link to comment Share on other sites More sharing options...
