StickyBL6 Posted December 10, 2015 Share Posted December 10, 2015 Hello, i reccently purchased a used 22mm Perrin RSB and it didnt come with bushing or mounts. I know I can use my factory mounts but I was told to use the AVO Rear Stabilizer Mount Brace (item number: S1104M1HT001T) with AVO bushings or Whiteline. my question is what would you recommend using for the mounts.. should I get the AVO or stay with the stock mounts and just use aftermarket bushing? I'm trying to figure out what i need/should get before I mount my RSB, Any advice is helpful. Thanks -Josh Link to comment Share on other sites More sharing options...
Redslaya Posted December 10, 2015 Share Posted December 10, 2015 get the bracing, you will need it. without it the stock mounts can bend or break off, and then you have a real problem Link to comment Share on other sites More sharing options...
StickyBL6 Posted December 10, 2015 Author Share Posted December 10, 2015 get the bracing, you will need it. without it the stock mounts can bend or break off, and then you have a real problem so your saying to invest in the AVO Mounts then? Link to comment Share on other sites More sharing options...
Rhitter Posted December 10, 2015 Share Posted December 10, 2015 so your saying to invest in the AVO Mounts then? Yes do it. My OBXT build Link to comment Share on other sites More sharing options...
Redslaya Posted December 11, 2015 Share Posted December 11, 2015 so your saying to invest in the AVO Mounts then? yes, they are a bit pricey, but cheaper than trying to fix the mounts. Link to comment Share on other sites More sharing options...
spec.B Dream Posted December 11, 2015 Share Posted December 11, 2015 Invest in the mount reinforcement. I had a mount break with the stock bar. Link to comment Share on other sites More sharing options...
98legwag Posted December 11, 2015 Share Posted December 11, 2015 I have the AVO mounts. I like them a lot. Link to comment Share on other sites More sharing options...
Dujo Posted December 11, 2015 Share Posted December 11, 2015 Yes to the AVO mounts. Link to comment Share on other sites More sharing options...
whitrzac Posted December 12, 2015 Share Posted December 12, 2015 Buy the avo or similar mounting brace. You should be able to find generic sway bar bushings/brackets that will work. Otherwise look for the whiteline/similar ones made for subaru. Link to comment Share on other sites More sharing options...
