Legacy53 Posted November 26, 2015 Share Posted November 26, 2015 Hey guys I have a 2005 legacy 2.5i and I want to put leather seats from a 2005 gt. Has anyone done this? Just wondering if it's an easy swap or a real pain. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
TiagoSantos Posted November 26, 2015 Share Posted November 26, 2015 Should be relatively easy.. I'm *fairly* sure the power plugs will be there already for the seat heaters (does the 2.5i have heated seats?). The seats themselves will bolt on, just make sure you get the correct rear seat (wagon vs sedan) edit - I got 2007 LGT cloth seats onto my 2006 OBXT LTD. My car had heated, power driver and passenger seats, the cloth seats are heated but manual on the passenger side. Everything plugged in just fine except the power plug was different on the driver side. I cut the plug from the car and replaced it with the plug from the donor car. I think the difference was a year thing, should be the same in your case.. Link to comment Share on other sites More sharing options...
Legacy53 Posted November 27, 2015 Author Share Posted November 27, 2015 My car does not have heated seats, that's the issue. If I can't get the heat to work right away that's not a problem with me, as long as the airbag light doesn't turn on and the power controls work. Thank you @TiagoSantos Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
