argyle409 Posted November 16, 2015 Share Posted November 16, 2015 I've pulled my headlights apart and in the process of blacking them out. I want to put halos on the projector shrouds, from what I read 80mm is the size to go with. However I've found very little info on what wire I would need to tap into to get power to the halo rings. I found some switch back halos that are pure white as DRL but then switch to amber when the turn signal is engaged. However I disabled my DRL since I have HID's as they caused the lights to flicker, is there an alternate way to have the halos be pure white under normal driving conditions with DRL disabled? Additionally anyone that has wired up halos, how did you go about wiring them, is there additional drivers I need to have them work properly? Switchback Halos Link to comment Share on other sites More sharing options...
