dongtokes Posted November 15, 2015 Share Posted November 15, 2015 I don't need to know how to pull all the trim off, I just need to know what the bulb numbers are in the instrument cluster. I counted 4 bigger bulbs that go behind the Speedometer and tact, but I counted 8 others and don't know what size are they are. Also, if I put a red LED's behind the speedometer will that gauge then change to red, or will the green tint on there mix with the red and create a different color? I want to change everything over to either red or blue, but I'm still deciding... Link to comment Share on other sites More sharing options...
ehsnils Posted November 15, 2015 Share Posted November 15, 2015 You better ask that question in the appropriate forum for your model year. Link to comment Share on other sites More sharing options...
dongtokes Posted November 15, 2015 Author Share Posted November 15, 2015 Well the only reason I didn't is because I figured there's not much difference between the different model's gauge clusters. Link to comment Share on other sites More sharing options...
ehsnils Posted November 15, 2015 Share Posted November 15, 2015 It's quite a difference from a model from 1990 (1st gen) and today (6th gen). Look up the appropriate forum since every generation is different. Link to comment Share on other sites More sharing options...
Brady Posted November 15, 2015 Share Posted November 15, 2015 Damn Millenials Link to comment Share on other sites More sharing options...
