headlights diag...
Which fuse is blowing?
I think there's one fuse for the passenger headlight, and one for the driver headlight in the engine bay. I would check the driver headlight fuse there, unless that's the one you're referring to.
I had an HID kit with harness, drivers side stopped working. no flicker just dead. stuck in regular bulb and its dim.
removed HID both sides, passanger is perfect drivers dim.
only common link is relay, and bulb socket.
blows the fuse under the dash
so... 1 new relay and 2 blown fuses later. all lights are good with normal function. not sure what fried everything but... not gonna worry right now. during my normal pre winter maintenance coming shortly im gonna clean all grounds, check harness and few other treatments.
