Greyguild Posted October 28, 2015 Share Posted October 28, 2015 Hi all, got an easy one for you... I have to press really low on my clutch pedal to be able to change hears, the pedal is so low that I'm not even sure I"ll be able to put rubber mats this winter.... How can I fix this please Thanks in advance Link to comment Share on other sites More sharing options...
Rideredmx38 Posted October 29, 2015 Share Posted October 29, 2015 First make sure your clutch fluid level is good if it's low you could have sucked air into the system if that's the case Try bleeding your system if that doesn't work replace your master cylinder and your slave cylinder (also called release cylinder in the cars Manuel) and it's also wise to replace them both at the same time Link to comment Share on other sites More sharing options...
twisty Posted November 2, 2015 Share Posted November 2, 2015 i have the same issue, but its a cable clutch. im betting on a bent fork, personally. as for yours i agree on the bleed first thing. start there, see what happens. Link to comment Share on other sites More sharing options...
