Mike C Posted September 27, 2005 Share Posted September 27, 2005 I installed the unorthodox pulleys a month or so ago, and now when the car is cold and I accelerate through a sharp turn, I hear the power steering squeal like a 5 year old <Insert Random GM car here>. I assume this has to do with the belt being too tight or loose, any ideas before I start experimenting? The fluid level is ok. Doesn't happen after car warms up (I think the belt is too tight). Link to comment Share on other sites More sharing options...
melayout Posted September 27, 2005 Share Posted September 27, 2005 The squealing occurs on meh bone stock LGT. Also, "car is cold" and "accelerating through a sharp turn" shouldn't be in the same sentence, STOP IT. I keed I keeed Link to comment Share on other sites More sharing options...
Mike C Posted September 27, 2005 Author Share Posted September 27, 2005 I meant dropping it into third and making a 90 degree right turn. Not really killing it! The squealing occurs on meh bone stock LGT. Also, "car is cold" and "accelerating through a sharp turn" shouldn't be in the same sentence, STOP IT. Link to comment Share on other sites More sharing options...
agctr Posted September 27, 2005 Share Posted September 27, 2005 I would say the belt is too loose, just try adjusting yrself, if unable to, just get the dealer to tighten up. Ada///M. Link to comment Share on other sites More sharing options...
Mike C Posted September 28, 2005 Author Share Posted September 28, 2005 Thanks Adam, will tighten them tomorrow morning. I would say the belt is too loose, just try adjusting yrself, if unable to, just get the dealer to tighten up. Ada///M. Link to comment Share on other sites More sharing options...
