gtonstilts Posted April 29, 2016 Author Share Posted April 29, 2016 on mine the only thing that rubbed with stock lgt struts was the tire-strut, in that case an offsett that was closer to negative would keep you from rubbing the strut. but as mentioned above its tougher on bearings and require some fender rolling im currently running swift springs, 245 45 17 tires on 17x7.5 and believe it or not a +15 offset ! keep in mind its an outback so i have flairs and it dosn't stick out past the body, i did have to cut the crap out of the metal fenders underneath though when i added the swift springs ps this link is best ive ever seen for wheel sizing/offset guide https://www.rimsntires.com/specspro.jsp Link to comment Share on other sites More sharing options...
Macdaddy911 Posted May 3, 2016 Share Posted May 3, 2016 Thanks awesome info guys. So would suspension from an 05 sedan work for an 06 obxt? I never carry anything in the back of that is an issue between sedan and wagon suspension. Link to comment Share on other sites More sharing options...
Rhitter Posted May 3, 2016 Share Posted May 3, 2016 Thanks awesome info guys. So would suspension from an 05 sedan work for an 06 obxt? I never carry anything in the back of that is an issue between sedan and wagon suspension. Yes, but add a 3/8in to 1/2in spacer to the rear to get it to sit level. My OBXT build Link to comment Share on other sites More sharing options...
gtonstilts Posted May 3, 2016 Author Share Posted May 3, 2016 rear wagon springs are only $60 a piece from the dealer fyi Link to comment Share on other sites More sharing options...
housemusic1 Posted May 3, 2016 Share Posted May 3, 2016 I needed 3/4" to sit level. Anybody ever look into metal spacers vs. the UHMW? Link to comment Share on other sites More sharing options...
Rhitter Posted May 3, 2016 Share Posted May 3, 2016 I needed 3/4" to sit level. Anybody ever look into metal spacers vs. the UHMW? Yep, they are just expensive compared to UHMW. My OBXT build Link to comment Share on other sites More sharing options...
gtonstilts Posted May 4, 2016 Author Share Posted May 4, 2016 i would highly recomend using a spring helper or a booster/spacer that goes between the strut and spring or between coils of the springs. using saggy but spacers does nothing to gain stiffness, or increase the usable strok of the strut. by using to short or weak of a spring, the strut will be closer to bottoming out at a resting height, this will cause a rough ride and wear the struts out very quickly. Link to comment Share on other sites More sharing options...
