Killuminati206 Posted October 23, 2015 Share Posted October 23, 2015 I this is an 05 legacy gt. I just got a cobb accessport need some help, i cant read the data logging want to know if everything looks ok. Thanksdatalog1.csvdatalog2.csvdatalog4.csv Link to comment Share on other sites More sharing options...
Killuminati206 Posted October 24, 2015 Author Share Posted October 24, 2015 Please!!!!! Link to comment Share on other sites More sharing options...
gtonstilts Posted October 24, 2015 Share Posted October 24, 2015 not enough info you did not log AFR which is the most important thing, ps if you have no wide band or way to log a wideband o2 sensor than there is no point the factory o2 sensor stops being accurate around 11.5:1 and at full boost you should be 10.8-11:1, only cars with front mount intercoolers can get away with 11.5 afr try again and make sure you log the following g/rev, afr, knock sum, fbck, fine learn, manifold corrected psi, total timing, wgdc, throttle, and RPM Link to comment Share on other sites More sharing options...
Killuminati206 Posted October 24, 2015 Author Share Posted October 24, 2015 not enough info you did not log AFR which is the most important thing, ps if you have no wide band or way to log a wideband o2 sensor than there is no point the factory o2 sensor stops being accurate around 11.5:1 and at full boost you should be 10.8-11:1, only cars with front mount intercoolers can get away with 11.5 afr try again and make sure you log the following g/rev, afr, knock sum, fbck, fine learn, manifold corrected psi, total timing, wgdc, throttle, and RPM What is afr? I couldn't find it while configuring it. If you didn't know I'm a noon I and don't know the abbreviations. Link to comment Share on other sites More sharing options...
Jaybird2013 Posted October 24, 2015 Share Posted October 24, 2015 A/F sens 1 Ratio is the parameter that you are looking for. Link to comment Share on other sites More sharing options...
Mike07LGT Posted October 30, 2015 Share Posted October 30, 2015 Air fuel ratio =afr 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
